2jzgte arp installation
Practical Engine Building
Andre mentioned 3 stages of 30,60 and 85 ft lbs does this also mean this should also be loosened At 30lbs and tightened to 60 then loosened at 60 lbs tightened to 85 lbs finally in the Toyota protocol sequence ?
Hey,
In my Nissan world, I only follow the ARP instructions in the ARP Studs kit. They won't stretch the same as the OEM ones. The only thing that is the same as the OEM instructions is the order in which you tighten the nuts.
Here's an example of the kit instruction provided by ARP (For RB26) : https://tech.arp-bolts.com/instructions/202-4207.pdf
