Applying Sealant under the head gasket
Practical Engine Building
Hi Andre,
I am wondering why you had to apply a sealant under the head gasket at the front cover level in the SR worked example.
It's because there is a join between the block and the front cover here which can promote a leak. This bead of sealant is as per the workshop manual.
Thanks Andre!
