Conrod Balancing
Practical Engine Building
When weighing the conrod for balancing should you have the bearing still installed (old ones) or should these be removed for balancing?
Without the old bearings,certainly, normally without any bearings*, anal with the new bearings.
*if one were to be fussy, you could check the new bearings masses and also balance those.
