Cyl oil
Practical Engine Building
Hi andre i noticed in the assembly that you didnt put oil on the cylinder bore walls is there any reason for this? or is just oiling the rings and skirts fine? Made me wonder about corrosion on the cylinder walls if they were left un protected between asembally and first start up
