Dry Sump can effect Piston to wall clearence?
Practical Engine Building
we know the dry sump gives us the advantage that we can use lower tension ring pack with better seal. so can it effect the piston to wall clearance?
Uh, no - that's a factor of piston expansion from combustion heat and, to a lesser extent, block expansion.
So, can be effect directly in quality of cylinder pressure, because the ring work with differential pressure to work
