Help!!! one piston 2.3.G heavier then the rest!!
Practical Engine Building
Hi,
I am currently balancing my CP pistons and one of them is a lot heavier then the other 5.
I have weight matched my pistons down to 356.9 however the last piston weighs in at 358.27G so a 1.37G difference
my problem is I’m going to have to remove a lot of material to get this down to within a 10th (356.9)
is this ok?
hello, I have actually never had a set of cp pistons that far out i would be ringing cp for advice on where to remove the weight and actually asking for another piston if you are concerned about the amount you have to remove.
Regards Ross
