Inline 5
Practical Engine Building
How i balance inline 5 pistons and conrods?
In the same way you'd do a 4 or 6 cylinder engine's components. For the full balancing you'd have an engine balancer do the balancing of the complete assembly, as if the crank was correct from the factory, your removing a small amount of material for the initial piston/connecting rod balancing will mean the crankshaft is now out of balance - same as any other engine.
thank you!
