rb26 build.
Practical Engine Building
I'm rebuilding my rb26 myself this time round so learning with the machine shop giving me some guidance. I have a set of bearings in and arp studs and torqued crank down with plastiguage after we did some initial measurements.
From front of engine clearances are in thou 1. 5 / 1. 5 or less / 1. 5 / 2 / 1. 5 or less / 1. 75 or more / 1. 75 or more
The more or less is when it's just a smidgen bigger or smaller than the reference paper shows.
From what I have read here 2 to 2. 5 is my goal?
Will be running an external dry sump system.
Also what is the recommended rod bearing clearance?
Pic of measurement
