Ends in 6 hours
RB26 OEM Piston clearance on 86mm bore
Practical Engine Building
Hello,
I'm still learning but decided to stick a bore gauge down my RB26 block and get some measurements and mic the piston skirts. I'm trying to find information about the RB26 oem piston / bore clearance. Does anyone have easy access to that info?
Also, how do these numbers look? I know I forgot to write down a couple on cylinder 6. I'm going to go back through and recalibrate my micrometer, then re-zero the bore gauge and check all these again today.
Thanks in advance
the factory clearance is pretty large in a standard form with anywhere from .0035 to .005 tho being acceptable i personally like to run them a little tighter when reboring using std oversize cast pistons ( i like to see .003 -.0035 )
Title
Text
