Thrust washer fitment
Practical Engine Building
Hi good day hpacademy I just want to make sure I have it correct . The thrust washer groves will face the inside of the rod face and the flat side of the thrust washer will face the block ? So when installed correctly the builder should see the groves of the thrust washer without the rod installed on the crank ?
The grooves in the thrust washer face the thrust surface of the crankshaft. The flat side of the thrust washer should face the block.
