2 core screen for can bus
Hi
I have spare 2 core twisted shielded cable that I have used for my cam angle ,crank position and knock sensor is it ok to use this on the can bus wires also ? I noticed in your webinars you haven’t used this but from the webinars I’ve seen you haven’t specifically said not to use it
I’m using a
link fury g4x ecu
Aim PDM with keypad
can bus wideband sensor
Many thanks
Axel
Hi Axel,
No reason that you cannot use that cable, but unless it is being used in a really electrically noisy environment, it is overkill for CAN bus wiring.
