Battery, starter, and alternator wire gauge and feedthrough.
Hey all,
I'm rewiring my car and plotting things out. The battery is in the trunk, it's a normal AGM battery. The engine is a GM LFX (3.6l DI V6) which is known to be finicky about starting with low voltage due to DI fuel injectors. The alternator is rated for 120A, it's a one-wire TuffStuff unit.
I'll have a single firewall passthrough, possibly a stud, so that on the cabin side I can have the cable from the battery to the feedthrough, and a cable from the PDM to the feedthrough. Then on the engine side, have the cables to starter, the cable to alternator, and possibly ABS and EPS cables as well.
Have any advice on wire sizing and feedthrough options? A Surlok would be nice, but then. I'd have to have a spliced/branched power cables?
Thanks
Dan,
I am in the process of redoing a replica cobra. Trunk AGM battery, about 8' of cable from the battery, thru the disconnect to the solenoid to the starter. It was originally wired with #2 cable and I am experiencing some major voltage drops as the starter does its thing. One of the steps to help resolve this is to change the positive and negative cables from the battery to 2/0 cable to reduce any potential voltage drop. I also don't rely on the frame for the ground, I run a cable from the negative to a stud near the starter, then a flex strap from the stud to the stater mounting bolt.
A direct path on the negative is as important as the positive path. 2/0 is twice the area of #2 cable and conductor area figures into the resistance equation.
Paul
I would at least run 1/0 from battery to starter and as stated above from battery negative to block.. the block to chassy... then you can run a 4ga from starter to the 12v pass-through. Then you'll have the cabin side to branch out to the pdm and to feed the other 12v.
What ecu and pdm are you using?
+1 for Paul's comment on the ground being as important as the positive path since that's very often overlooked, and I diagnose far more ground side issues than power side ones.
I'm running an AiM PDM32 and the stock GM ECU (E39A). The car currently has a 0awg cable from the battery in the trunk straight to the starter from the original battery relocation project. I was hoping to keep that cable for the battery to firewall run, but could upsize I suppose.
I understand the importance of the ground path but.. is the chassis really insufficient if the connection to it is proper? it is all steel with no adhesive bonding like a modern aluminum chassis. I could weld a bolt/stud to the chassis near the battery for a good bond potentially. And maybe also in the engine bay to ground the block. I guess I'm trying to avoid the weight and bulk of a second battery cable run, but maybe it's not terrible.
Because it's a relatively short run from the firewall to the starter, I was thinking 2awg. Then 4awg from that same point on the firewall to the alternator. I I can more easily clear the headers by running alternator from firewall to alternator instead of jumping from the starter. What do you think?
Thanks!
Guys,
Do you run a separate cables from your bulkhead studs to starter and alternator? Or do you run a single wire from bulkhead studs to starter and then starter stud to alternator?
Does this single cable provide charge from the alternator back to the battery?
For me it depends on if the car can be isolated by it's kill switch running it like that. Most of the time, that is what I do. 1 bulkhead with the alternator jumped off the starter stud. Saves weight and wire, but there has to be room to junction at the starter and the kill switch method needs to take this into account (don't forget about alt load dumping, the alt doesn't like losing it's load when its still spinning/charging). Yes it will charge the battery like that.
I'm still spinning on this. Granted the garage has been cold and progress slow.
My alternator is on the opposite side from the starter and the battery cable will enter the engine bay on the alternator side. So I don't really want to cross over to the starter and back across to the alternator.
I still can't think of a better plan than a feedthrough stud on the firewall and just running the starter, alternator, ABS, and EPS all off of the feedthrough stud independently. I'd put an inline fuse on the EPS and ABS wires. Can I stack four ring lugs on the stud? It does make it so the wires have to sort of splay out which is kind of ugly. If the stud was long enough I could stack copper/brass washers in between ring lugs so they don't interfere with each other maybe.
I looked at SO many distrubtion blocks with and without fuses.. I can't really find a clean solution that isn't too big.
As for wire gauges, I'm thinking:
1awg for 6ft battery run to in the cabin to the feedthrough
1awg for 3.5ft run from feedthrough to starter
4awg for 2ft run from feedthrough to alternator
6awg for run (60A) to EPS
8ga for run (40A) to ABS
Yes, that's not a problem.
Just make sure the 'tags"and wiring doen't interfer with each other, preventing it being tightened down evenly.
One trick, that should help (depending on lug design) is to pair them up, back to back, to help with the wire routing - think a "V" rather than a four pointed star.
Thanks, a feedthrough stud it is. I'll find inline MIDI fuse holders for the EPS and ABS.
I updated the wire sizing in my previous post. What are your thoughts? Am I being too skimpy?
Your wiring looks fine to me, larger than anything I use.
Think I could get away with 2awg on the battery and starter?
Probably. 10' is not very far, and unless you have a very weak starter, or super high compression, I can't see how that would not be sufficient.
