BMW M62 Coil Pack Connector
Hi!
I'm building my first wiring harness and I've managed to hit a wall right at the beginning. The harness is for a BMW M62B44 and I want the use the OEM Coil packs, however I can't seem to find the appropriate connectors for them. Tried googling and the only website I found was this. This seems to be the right connector, but I guess this is the manufacturer's website and I don't really need 10.000 connectors right now. I looked for a seller on eBay, etc. but found nothing.
I still have the original connectors (pictures are included), but I do want to re-pin them. Does anyone know where I could source pins for this type of connector or new connectors all together?
Not one I've struck before, so I can't be any direct help, but having actual BMW branding embossed on to it might make it tricky. Have you tried your BMW dealer?
Oh, a super quick google of 1724478 found plenty of sellers, have at it :-)
https://www.ebay.com/itm/1724478-BMW-VW-Ignition-Coil-Wire-Harness-Plug-3-Position-Connector-w-Terminals-/182321077636
I must be going blind or something. :) Thank you Zac!
Edit: Seeing that the ebay link is not alive anymore here's some extra information. I found out that the terminals are called "Standard Power Timer" and are available from this ebay store. The smaller version is called "Junior Power Timer" which was/is used in injector and sensor connectors, is also available.
