Bosch DF11s Wheels speed sensors
So I'm trying to figure out how to wire a full set of Bosch DF11s WSS into my Haltech 1500 in order to do traction control and im having a hard time figuring it out, i've attached the technical sheet to this post, but I'm not sure how much help it'll be.
Ive got the wheel speed sensors currently assigned to my Synchronised pulsed inputs, my main question is do I feed 12v into the other side of it and will the Haltech be able to understand the sensor?
That's a current loop sensor. You will need to add some resistors to create a voltage that the Haltech will be capable of measuring. Start Googling 'Current Loop Sensors' for infomation on how to deal with that.
Hi luke, did you get read df11s with elite 1500?
how wired them to ecu?
work fine? also would like use df11s with elite 1500
Output was hall digital as bosch document, or sine wave as vr (ask, because only see 2 wires).
