Braid and Foil Drainage
Relevant Module: Practical Wiring Harness Construction Skills > Splicing to Shielding Braid
Hello
Really enjoying this course! Just a quick quesion re this lesson
(https://www.hpacademy.com/dashboard/courses/practical-harness-construction-club-level/practical-wiring-harness-construction-skills-splicing-to-shielding-braid/)
If the shielding is BOTH braiding and foil, do I follow the same process? Or trim te foil?
Best
Michael
Here's an interesting paper on shielded cables : https://www.mouser.com/pdfdocs/alphawire-Understanding-Shielded-Cable.pdf
As the foil will be in contact with the braid, the easiest is to crimp a drain wire to the braid and ground it at one end.
Great, thanks!
