Ends in 5 hours, 59 mins and 59 secs
C125 Dash Manager CAN Problem
Hi,
We have been having problems getting this pressure transducer setup in our C125 to log via CAN. We believe the wiring is correct, but have had ton of issues trying to get the hex IDs to read in the system.
Is there anyone out there who would be able to set this up and potentially export it for us to take a look at?
Any help would be possible!
Thanks
Hi Ryan,
Best starting point would be to use CAN Inspector to verify the C125 is actually receiving data.
This is available for download from the MoTeC website as part of the utilities package (search 'utilities')
You can select the CAN interface of any compatible MoTeC product and capture all messages visible to this interface in raw hex format.
Once you have verified your C125 is seeing the messages next step is to confirm you have your CAN setup correctly in your dash config.
Something like this you would probably be best off creating a dbc and using the dbc import tool.
Title
Text
