Can I use both wires for two different signals in a shielded twisted pair?
Hi,
In the OEM wiring for a SR20DET CAM sensor, there are four pins; power, ground, CAM angle 1 degree and CAM angle 180 degree. On the shielded twisted pair wiring, both CAM angle wires run on the same twisted pair and the shield is grounded. So in theory is it okay for me to use the same twisted pair you show here and run two different signals on the wires as long as I ground the shield? or should I run two lengths of twisted pair?
Thank you.
It will be fine to do that but ideally, separate them.
Regards Ross
