Coil Pack and Injector connectors
Greetings All. I'm almost at the tearing hair out, slashing wrists stage . . . so before I take the final step into madness I'll cast my net wider. I'm in the process of building a full loom for an Alfa 147GTA rally car and none of my (usually reliable) sources can supply me with the correct connector kits for the injectors and coil packs.
I've attached a quick pic showing the external dimensions of both. The injectors are Bosch 0 280 156 038 the coilpacks are Bosch 0 221 504 456
Any suggestions as to where I can get these connector kits? (Unfortunately it is not currently an option to re-use the connectors from the donor car, over a decade of engine bay heat has rendered them "unserviceable" )
The coil pack looks a bit like a 3 pin junior power timer. Have you tried one of them?
The injector looks like a common 2 pin ev1 / junior power timer style connector. But possibly with a alternative key way that migjt need trimming.
They can be bosch, or replications from TE i believe.
Although im sure you would have tried them as they are very common connectors.
2 pin junior power timer
I'd agree with Bram here, thats what they look like they'd be, to me? Have you had a chance to try these connectors out at all?
