earth bonding
Relevant Module: Practical Wiring Harness Design Skills > Grounding Design
hi there
sorry to ask but i am abit confused. so for the efi system, i made a connection from the negative side of the battery to the chassis and then i passed a seperate wire wire from the negative side of the battery to the engine block. like that is ok please?
That should be fine IF all the ECU sender electronics use the same ground point.
duplicate topic, closed
