Ends in 5 hours, 59 mins and 59 secs
Ford Focus Bulkhead
Hey there folks! Need some help ID'ing a couple of connector bodies. Goog'd the numbers on them and couldn't find anything except that they may be by a brand called Yazaki- unsure if that is even accurate. These are the bulkhead connectors from the L side wheel well of a 2002 Ford Focus SVT, should be the same as a standard Focus. Bonus points if anybody's got any idea what the pins may be called or who manufactured them. Thanks friends!
While Ford and Yazaki have a strong relationship, I believe that connector is an EPC. I've always had a hard time finding terminals for those, occasionally someone on ebay has a reel of new old stock or something.
I think the series is called SP/MP, hybrid give the two terminal sizes in it. The last 3 digits of the part number are the configuration, Ford used the same housing with different layouts of what pins were used vs blocked. I've actually had success drilling out the back part before and adding terminals where there wasn't any before.
https://www.connectorpeople.com/Connector/FORD/F/F57B-14A624-DB
You can start digging here, I'd love to know if you find a source for these terminals.
Thanks Tyson- I'm on the hunt. What's the technique for depinning/repinning these and what pins do they use, if you've got that info on hand? They're the only connectors standing in between me and this harness build!
If memory serves (and based on the photos) you pull/pick out that white keeper in the middle and poke the tabs holding each terminal in and pull back on the wire. Same as most connectors
Careful as their probably fragile from age at this point
Title
Text
