harness
currently taking wiring fundamentals, club and pro aswell. I have an engine harness that i have to modify, it has a milspec firewall connector and the sensors are oem. it is braided sleeved, to an oem obd1 connector nissan sr20 (i have the correct pin out supplied by nismotronic to use on their ecu package)and hope i have the right ditributor pin out, to an sr20ve dual solenoid neo vvl and 6 speed transmission . Some of the pins need to be switched around, lengthen wires and i'd like to have documentation on it. Plus I'm integrating it to a racepak pdm. My hw
1. - Ground , 2 - Power - ECCS Relay, 3. - Cam position sensor #3, 4. - Cam position sensor #4 , 5 - Distributor resistor/ IGN Check , 6 - IGN Switch , 7 - Ground , 8 - Distributor Power/ IGN Signal
need a little bit of help identifying this connector, brand , style
thanks
