Help with CLT connector
I'm trying to find a connector for the coolant temperature sensor on a 90-93 1.6L Mazda Miata.
It looks like a TE Junior Power Connector with the key in a different spot. The only JPT connector I can find has the key in the middle, but this needs it offset.
In the attached picture, the green connector is the original - the one I need. The black connector is a JPT connector.
Any idea if anyone still makes this connector or where I can get it?
Thanks!
You might start here, and drill down into the various keying options to get the actual housing part number:
https://www.te.com/usa-en/product-282189-4.html
Hi David,
I've already spent the afternoon looking at TE's website. I've found housings with 4+ pins that have different key locations, but all the 2 pin housings I've found have it in the middle.
I'll look again in case I missed it - TE sure doesn't make it easy.
Thanks
