Injector current calculation for proper wire size
What is a good rule of thumb for sizing wire feeding injectors? I've got a flow rate table with offsets in uS for fuel pressures and voltages for my ID1050x's but I don't understand how to estimate injector pulse widths/duty cycle.
Thanks
You need to know the resistance of the injectors. Usually around 10-15 Ohm.
If you want to know the maximum current draw (always open), you take Ohm's law:
U = R * I
I = U /R
U = 12 V (example)
R = 15 Ohm
Therefore your current draw would be:
I = 12 / 15 = 0.8 A
As you can see, they don't draw much current continuously so your wire size does not need to be huge. I always use 22 AWG for the signal wires and 22 AWG for the supply wires which splice into a common 2x22 AWG wire 12V feed which gives me a theoretic 10 A for 8 injectors, for example.
