Must a CAS be fused?
Good day,
Designing my harness for an RB 25DET Neo into a 280z , is it a good idea to fuse the CAS circuit (+12v supply) of the "Enabled Relay", not sure what's done in the OEM harness?
Thanks
Tony
Found a NEO circuit , safe to say I'll fuse the CAS 12V supply as above, if I've missed anything feel free to comment -thanks!
personally, on a build I'd ditch the CAS and install a basic trigger kit from NZ wiring and performance, the Nissan CAS' are getting old and problematic.
Yeah thanks Chris ,that’s the route I’m going , and will be fusing that circuit
The NZ wiring kit doesn't use the 12v, only signal and ground as it's a reluctor sensor.
If it's a Ross or PRP they require 12v in theirs.
