Ends in 6 hours
Need Help Identifying Terminal Pin
Hi all,
Anyone able to identify the type of terminal pin referenced within the attached photo? If so, any suggested manufacturers or websites? I'd like to utilize the existing OEM connector and need to source terminal pins (male/female).
Thank you
Chris
Need accurate size info. Might be one of these (note size difference 1.8mm or 2.8mm wide connector)
https://www.bmotorsports.com/shop/product_info.php/cPath/109_182/products_id/5796
https://www.bmotorsports.com/shop/product_info.php/cPath/109_182/products_id/5477
Thank you David, ended up reaching out to bmotorsports and they didn't have my exact terminal. The links you referenced seemed pretty spot on, but apparently they don't have them.
I may end up just using a DTM connector and repinning male and femaile terminal pins.
Title
Text
