Relay/fuse panel VS Bussmann RTMR
Hey,
Trying to debate which one I should go for.. custom fuse/relay panel or straight with a bushman RTMR with 5 relays and 10 fuses.
Planning on using a ecumaster black on a 1jz swap.
Price wise they seems to be pretty equivalent to each others. RTMR is pretty cheap by itself but adds up once you add relays and terminals.
On the other end, thought that going with a custom fuse/relay panel would be cheaper, but using good fuse blocks like a blue sea system is killing the deal.
Pmu is out of the equation for obvious budget reason
What are you guys using ? Pictures would be great too.
Thanks !
No picture immediately at hand, but I would vote for an integrated fusebox solution like the bussman products. They work out quicker, easier, and usually tidier also.
