Single wire connectors
Do any “nice” single wire connector exist like the Deutsch connectors? I have a few components that I’d like to connect in to my more loom
Are there any good connectors that allow you to join three wires together?
kind regards
Rob
Do you need to be able to disconnect each one independently, or two are logically one one side of a connector, and one on the other? If that were case, I would use a DTM-2, and just splice this one-wire side to go to both terminals.
Hi ideally disconnect each one independently
If you don't need to do this often, then de-pin the DTM-2 when needed.
yep - will do that then!
