Problems with sketching the three bolt holes - 2D Sketching Module
Relevant Module: Solid Modelling Basics > 2D Sketching
Hi everyone,
I am following along at timestamp 05:06 and the course instructs to sketch three 11mm bolt holes starting with the top one which is snapped onto the y axis above the 61mm circle. When I try to create the other two circles as per the instruction, "without dimensioning", I am forced to dimension the circles which results in an error when trying to use the equal constraints function. I am pretty sure my circles are fully defined but I am confused. Any help is greatly appreciated!
Thank you,
Connor
Update:
Just realized I had my first (of many) brain-fart moment and solved my issue. So far, I am loving the course!
