Struggle with files
Relevant Module: Solid Modelling Basics > 3D Sketching
Hey guys. I’m really struggling to download the files to use so I can follow along. I eventually managed to get the 3bolt file from earlier on download unsure how it happened in the end. Now when I try download this one it all goes good but when I up load it and right click it doesn’t give me the option to open it in fusion. When I double click it it opens up into another window just with the file info. Hoping it’s something I’m missing or doing incorrect that I could be pointed in the right direction. Cheers guys
Hi Jimmy,
check out the screen recording I've attached.
Is this how you're doing it?
cheers,
Connor
  • Screen-Recording-2023-06-09-at-9.38.36-AM.mov
Yea I have been doing it that way. I managed to get the 3 bolt flange after a fair few attempts. Trying to get the roll cage main hoop on for the 3D sketch module. I can download the file but it’s coming up as like it’s uncomplete. Instead of having the image there like the 3 bolt one has come up in the data panel the roll cage hoop one is just a dull box showing up instead of the part. Followed along with what your reply was and still can’t seem to get it to the point of been able to upload it to fusion. Hope this kinda makes sense. Cheers James
The file says it’s a zip Archive where as the 3 bolt one I can use says it’s a fusion 360 file. Is it possible something with my computer? Cheers James
Have you tried unzipping it? You may have accidentally set your files to automatically zip to save space.
I just did a quick youtube on how to unzip files and this has worked. Ill try figure out how to unset the files to automatically save to zip. Thanks heaps for your answer. Cheers James
