Motec C127 GT86 .dbc file
Professional Motorsport Data Analysis
Hi guys,
Would anyone happen to have a working .dbc file for the motec c127 using the factory ecu's?
I would like to be able to view and log the Wheel speed sensors, brake pressure, steering angle etc.
Just got the dash and fitting it up to the car. We have the first event of the season this weekend and don't have enough time to decode everything.
Any help would be greatly appreciated.
Thank you
I don't have a DBC file, but here are some FT86 CAN addresses for you:
Wheelspeeds (FL, FR, RL, RR) CAN ID 0x0D4, two bytes each
Steering CAN ID 0x18, Offset 0, Len two bytes
Brake CAN ID 0xD1, Offset 2, Len 1 byte
TPS CAN ID 0x140, Offset 0, Len 1
Thank You david! That's great enough starting point.
The brake is brake pressure or brake switch?
Not sure, probably just a switch.
Brake Pressure.
