Ends in 5 hours, 59 mins and 59 secs
bulk head connector
i have technical question, if my harness made two pieces with bulkhead connector, which is the best one to use and can i pass the power 12v inside the pin and would the pin hold for this voltage?
Hi,
This is the one I use for people on a budget.
https://www.connector-techals.com.au/products/deutsch-connectors/deutsch-hd30-panel-rec-47-way-skt-cont-metal-ip66-13-7-5a-et-seals
And if you're doing a full motorsport grade build you can get your connectors from here:
https://www.motorsportelectrics.com.au/shop-by-product/category/autosport-connector-kits
Title
Text
