Garrett turbo speed sensor for G Series
I have purchased a couple of speed sensors for my Garrett G series turbos (See attached image)
Each have 3 cores within a premade cable and a HUGE manufactures plug itself covered in heat shield.
We need the sensors for mapping the engine, to ensure the turbo is in the correct operating envelope.
My question is
I cannot find technical details of the speed sensor connector, i.e. why is it so large?
I am presuming there is circuitry within the connector body ? I would like to use a Deutsch ASL connector.
If there is circuitry in the connector, then my only option will be to ‘pott’ the manufacturer's connector.
If there is no circuitry in the connector, then i could cut off manufacturer's connector and replace with Deutsch ASL connector.
I appreciate any feedback
Many thanks
Tony
The circuitry in the harness is probably a frequency divider as some ECU can't keep up with the high frequency output of the sensor. The connector seems to be a AMP Superseal 1.5 with 3 terminals.
You said you purchased the sensors, can you contact the manufacturer in order to get the specs from them?
I know this is an older post but...
I have installed a turbo speed sensor from EFI Solutions in Australia and it is noted as Borg Warner and Garrett. The sensor itself is a Jaquet unit and the circuitry on the plug end is a signal divider. This particular one divides it by 8.
I was thinking of cutting off the end and using a DTM3 plug because it was fairly bulky like you say, but then I realised it was an important part of the sensor so left it and used the suitable GM plug for the other end. The harness I have built isn't top spec motorsport but still a high quality clubsport harness with DR25 and SCL. Just not fully sealed and booted at all connectors.
