Splicing Rule of Thumb?
Hey guys,
I'm making good progress on my pin out diagram and laying everything out for my build. I'll be going with an AEM Infinity Series 7 ECU and was wondering if there is a rule of thumb when splicing sensory supply and sensor grounds from several sensors on which ones you should pair together or some that your really shouldn't share. Similarly on actuators. I tried sticking with anything coming in/out of the first main connector stays on that connector and anything going in/out of the second main connector stay on that connector, but there are shared items across both connectors (for example injectors are wired to both connector 1 and connector 2).
Or should you just stick with trying not to splice out more than 4 connectors to one pin?
Thanks,
Sean
Bump, good question that I was wondering as well!
With the infinity it doenst matter - as far as I know they are all connected internally to the same 5V/Gnd rail. With some ECU's such as Motec M1 they have the 5V and 0V pins marked in A/B/C pairs so you can get better accuracy from ratiometric sensors but that is an exception rather than the rule.
Thanks for the reply Adam!!! Glad I don't have to go back and redo things :)
