Wiring to PCB - Solder?
Just wondering what would be the best way to terminate and strain relief wire and connectors to a PCB board if needed. Would support with epoxy be the answer to hold the solder joints in place or is there a better method?
I know Autosport do PCB mountable connectors but would also want to wire to it also?
For example i've got a junction box that will contain a small self built PDM for powering coils and injectors but also deals with analog/sensor inputs coming into it and placing that information onto the canbus for dash logging and vital ECU inputs will go direct to the ECU input.
