Torsion release bearings
Hi All,
Has anyone tried these? If so any tangible benefits? https://eibach.com/product/TRB200
Thanks,
Ben
Yes, any friction in the suspension is the enemy of grip.
They will be of benefit, but how much is difficult to say.
With coil springs, there is a small torsion, or twist, affect as the sping is compressed and extended, and that can both provide a small steering force on front struts, and affect the spring rates a small amount. In some instances fretting at the seat and spring interface may be seen.
They won't hurt and may be of benefit.
You will need to make sure they're kept clean and lubricated, as if they stick you lose the benefits, if any.
I'm due to get the dampers rebuilt so will take a close look at the springs to see if there's any evidence of friction. I've been meaning to try this bearings for years, will give them a go this season. Thanks for the useful feedback all.
