AFR meter question
Understanding AFR
With the AFR controller meter, can that be temporarily installed or will it be a installed part?
The meter/gauge is not needed permanently
However a wide band O2 sensor feeding into the ECU is a very useful implementation which enables AFR triming and closed loop control and AFR logging
