Air Temperature Compensation
Understanding AFR
Hello,
if my 0 is at 30 degrees How do I build the table right?
Just move the numbers in the table right?
And what do I at 0 degrees or down, adding 2.5 each time?
Thanks and good day
It really doesn't matter where the 0 point is provided you make the same 2.5% step for each 10 degree change.
