Clarification on the Air Temperature Compensation Table
Understanding AFR
Relevant Module: Fuel Compensations > Air Temperature Compensation
In the lecture I understood that 20 degrees celsius is standard conditions and to fill that point with zeros. In the example table however the zero degree point is filled with zeros and the 20 degree point is filled with -5%. I am confused and hope someone can explain to me what I am missing.
