Desert climate
Understanding AFR
In the Middle East in the summer the wither is.very hot and the temperature reached 50C sometime do we need to make the AFR more retcher ?
As air temp increase oxygen density decreases so we in fact need to remove fuel at a rate of around 2% per 10 degree change.
Check out these 2 webinars which Might help with air temp correction understanding
https://www.hpacademy.com/previous-webinars/075-charge-temperature-compensation-link-g4/
https://www.hpacademy.com/previous-webinars/074-intake-air-temperature-correction-haltech-elite-2500/
