Full throttle
Understanding AFR
Hey, I am wondering how are you run on full throttle at 2000 rpm? You have a rev limiter there or?
You do that on a load-bearing dyno. These can be set to hold any specific RPM (or wheelspeed) allowing use of a range of throttle positions, including full throttle.
Ok, now is much clear. Thanks
