Idle, Cruise and High RPM Vacuum
Understanding AFR
from 1:19 to 1:52. So we have two numbers .95 and 1.00 lambda. I am assuming that in that lambda targets you would want .95 then go into the fuel cells and lean it out a bit then have the afr at 1.00, but targeting .95? This is all at idle btw.
Andre? lol
