Methanol afr or lambda voltage for drag turbo car
Understanding AFR
Hello... i start with a new client and we are running a methanol fuel and i have a lil of doubt about a good afr with turbo engines on methanol..
There's a table of stoichiometric AFR's for different fuels available to download on this module of the course:
https://www.hpacademy.com/courses/understanding-afr/stoichiometric-afr/
If you were to work in lambda it would probably make things a bit easier for you if you're switching between fuels
