Motorcycle 1 cylinder Beginner Tuning
Understanding AFR
Hi guys, newbie here just started on EFI Tuning and I'm starting smaller one to practice. Is it okay to tune using narrow band sensor (stock sensor) since there is no provision/connection external wideband sensor and data logger only live tuning?(Aftermarket ECU). What are the safest AFR target (95-100 gasoline) since I'm currently using high flow air filter and exhaust ATM.,
Hi
yes it is fine to just use narrow band as that is all I used to use in my early days of tuning
you will want in the area of 13-1 full power and 14.7 -15.2 for cruise and idle where it idles best on those bikes
Regards Ross
Thank you Ross.. I really appreciate it. It will helps me a lot as a beginner EFI Tuning.
you are welcome
