107 | Analysing Turbo Performance
Webinar Questions
Hi, would you please remind me what brand of backpressure sensor you are using? I watched tha in some of your videos explaining your Toyota car but can't find it... Thank you.
I guess I found it. https://fullfunctioneng.com/product/ffe-emap-canister/
Is that the one?
The sensor itself is just a 0-150 psi honeywell sensor. The damper we're using is from T1 Race but we also have the FFE ones for our RX7 so it's a bit of a coin toss.
The T1 damper is a very nice piece. You can usually achieve some good filtering with a similarly designed tube, with a small inlet hole and some steel wool media inside. But, if the budget allows I will go for the T1 race unit everyime!
Zack
