226 PMU - pre pump fuel pump
Webinar Questions
Hi
I am using the PMU16.
I want to run the fuel pumps to feed the lines for 3 seconds after turning ignition on.
Anyone found a solution for this within the PMU functions?
Thanks
Normally the PMU would be working with the ECU which is what controls the priming time. Either the ECU communicates over CAN requesting the fuel pump, or you use an output from the ECU connected to a switch input on the PMU.
