251 | Using RomRaider and MLVHD
Webinar Questions
Hello Andre,
on the last session of the webinar u mentioned the knock learning values and currently I think I am facing some issues to understand how to overcome situations where you can see different result from run to run due to knock learning tables adjusting my ignition timing table. I can the see on my logs every run the engine behave differently and shows different timing values which totally different from what been edited on the main ignition tables, so to go about that and do u have any previous webinar or worked example showing how to deal with such situations.
thank you
