Cam Timming
Webinar Questions
In the webinar you are dialing in the number 1 cylinder (Piston, intake & exhaust cam lobes). After the number 1 cylinder is completed, have you checked the other cylinders to verify the quality control of all of the cam lobes? If so, how do you setup the degree wheel?
There should be no need to check each individual cylinder, particularly if you're dealing with a reputable cam company. If you wanted to do so however you would just time the degree wheel to find TDC on the cylinder you want to check your valve events on.
