ECU information source
WinOLS Mastery: Map Identification & Editing
Relevant Module: The WinOLS Map Definition Process > Step 3: Understand What Maps Are Required
Discussion and questions related to the course WinOLS Mastery: Map Identification & Editing
Thank you Andre for this couurse which i was waiting for long time ago.
You represent well known ecu (med9) at the course which is good Because many people has worked at in terms of maps definitions, tuning and so on..
In opposite if iam working in an ecu which not famous such as bosch ME2.0 and Me2.8 how can i manage to find maps required for stage2 and up? The basic maps (stage1) available.
Hi Mohammed, understandably we can't cover every single controller out there, however we will be adding to the supported ECUs when we can. What we've tried to do is cover the ECUs as a family and there are generally consistencies in the strategy across a controller family so what we cover on the MED9.1.5 is still applicable to a degree to other ME/MED controllers. What specific maps are you wanting to find and define?
