Mini cooper JCW N14 MED17.2.2
WinOLS Mastery: Map Identification & Editing
Discussion and questions related to the course WinOLS Mastery: Map Identification & Editing
Dear all,
That will be my first post as a rookie on reflash. Please forgive any questions that I may come up with.
I have downloaded my ECU bin file and I can identify a couple of maps in Winols like kfmirl, kfmiop, kfwzp+/2, kfwop+/2, lamfa, Fkkvs, KFKE0/1/2/3, KRKATE, etc
My Mini cooper has a stock engine and the only change I have is a pipercross panel air filter.
1- I've been following close to the videos and the first question is , would it be possible to post the Bosh Acronyms of the Maps that you have been change in Winols Gof GTI Video?
2- Also, because my trims (LTFT+STFT) are arround 10%, I want to correct as close to possible to 0%. Do you know in which maps of MED17.2 should I look for correct this?
Best whishes for all
Cassador, how were you able to read your ECU? Were you able to access via OBDII, or did you pull the ECU out of the car?
