Question on Toyota Denso newGen ECU
WinOLS Mastery: Map Identification & Editing
Discussion and questions related to the course WinOLS Mastery: Map Identification & Editing
Hi all,
I'm trying to practise the skills learnt from the course and managed to found various map. The bin files used is from a Toyota Alphard 2.5 2ARFE with SW of 89663-58441. It is a Toyota newGen MCU D76F0XXX ecu. I have few questions that needs some assistance.
1) Has anyone know how does a Toyota Denso ECU flow works? i have found few maps that relates to torque and load but trying to link and make sense of them.
Torque Map
X : Pedal Position
Y : RPM
Z : Torque
Calculated Load (Air Load?)
X : Requested Torque
Y : RPM
Z : Calculated Load
2) Does anyone has a 2d snapshot on how does a limiter looks like on a Toyota Denso ECU? For Engine RPM limit and Speed limit.
Thank you
hi i did something on r7f7012 and i have a winols mappack + bitedit protocol for this ecu maybe we can understand somethinf from this? seems pretty similar
